When you find an error on your map what do you do? The first place you should look to report the error is the website for your product. While there are only a few companies that produce map data, some GPS software companies use multiple sources (i.e. for different parts of the world). These companies also like to make sure the problem isn't with their software. If you can't find a place to report map errors on the company's site the following are a list of the main map providers:
NAVTEQ (Mapopolis, HP, Destinator) mapreporter.navteq.com/dur-web-external/secured/submitDur.do
TeleAtlas (TomTom, Teletype, Navman) www2.teleatlas.com/Pub/Support/MapFeedback/index.htm
If you have comments or corrections to this list please send me email.
