In a nutshell here is the issue. I have a new to me (but used) 5455 running the latest available flashes and updates. (2003)
I have a BT-308 Bluetooth Receiver.
Software installed (the HP iPaq Navigation). PDA sees the receiver and connects, but for some reason the receiver can not find where it is on the face of the earth. Is the RECEIVER BAD? (worked before on another iPaq .. should be working now!)
FULLY charged and left on the charger .. solid green indicator light.
Help!
felixgza
The GPS receiver needs to "see" the sky, go outside.
Good and brief = twice as good
oldsoundguy
no workee!! 15 minutes and NO access.
oldsoundguy
OK .. tried it AGAIN, only this time I shut EVERYTHING off (powered down) and went outside and TURNED THEM BACK ON. The receiver FINALLY found where it was living.
So, this one is solved for now. Thanks for the reply.
Now to get the other two issues taken care of and I will be a happy camper!
