iPAQ hx2755
Windows Mobile 5.0
I am looking for a GPS Receiver with Bluetooth to interface with my iPAQ hx2755. I want to use it almost exclusively for real-time street navigation.
Can anyone recommend a small, accurate GPS receiver that will work well with my iPAQ hx2755 PDA using Bluetooth.
Thank you.
David Smith
dsmith30@satx.rr.com
oldsoundguy
look into the iPaq bt308. I have one and it seems to be a universal receiver as it is now on it's second iPaq and works. A full kit includes a Navtech map kit with 2 disks (but there is a charge with the map system to upgrade.)
Just remember that a GPS system is only as accurate as the map system it works with as far as instructions. You will get as accurate co-ordinates as is legally possible as the receiver works 12 satellites!
(but unlike TomTom, you can't change the voice of the navigator if you use the HP system.)
